unconfigure diffserv examination
Description
Disables DiffServ traffic groups.
Syntax Description
N/A.
Default
Disabled.
Usage Guidelines
Use this command to disable DiffServ code point examination.
The following command disables DiffServ code point examination:
This command was first available in ExtremeXOS 11.0.
Platform Availability
